I am Having Issues using the cable MTL solver in FEKO. I am replicating a single conductor above PEC ground transmission line which is excited by plane wave radiation. After creating the cable path, harness, connectors, and terminations I receive error 38287 stating that cable segment must be defined within .2 wavelengths from conducting surface. The entire cable is within this range and I am not sure what correction will allow my simulation to run.
