Transient heat transfer analysis and SPC power
Mathilde.L
Mathilde.L Altair Community Member
edited June 2021 in Community Q&A
Hi Everybody !
I am doing a transient heat transfer analysis and I would like to get as result SPC Power. I selected in the card control "GLOBAL_OUTPUT_REQUEST" the SPCF and I tried with different formats and options but I did not managed to get it in my result file... Is it possible to have it with a transient heat transfer analysis ? If yes can you help me ?
Thank you !
Mathilde
Welcome!
  • Adriano_Koga
    Adriano_Koga
    edited June 2021
    Hi @Mathilde.L
    SPCF is not available for any Transient run. Only Steady State. Do Element Fluxes helps you, somehow?
  • Mathilde.L
    edited June 2021
    Hi @Mathilde.L
    Hi @Adriano A. Koga
    Thank you for your answer. I know that I can get Element fluxes but I wanted SPC Power to compare it with the steady state analysis... Do you know if there is another way to get heat flow from the elements fluxes ? (derivated results etc...)
  • Adriano_Koga
    Adriano_Koga
    edited June 2021
    Hi @Adriano A. Koga
    need to try, but maybe results math:
    If you take the flux*area, maybe?
    But need to think about elemental results for flux vs spc nodal results.
  • Mathilde.L
    edited June 2021
    I already try this but it is working with shell elements and I use solid elements. I cannot get the area of solid elements
Welcome!
Welcome!
