I am following one of the example inside flux called: brushless IPM motor - thermal analysis.
Inside case 1 of the example, the mechanical set of the rotor has to be set. The instruction (p. 59 chapter 4.1.7) tells me to set the position of the rotor at time t=0s to 7.5 deg.
The number 7.5 deg seems very odd to me. Why is it not set to 0 deg? How can I calculate this position for any other motor then?
What's even more interesting is that all steps from this example are already done for this model. I am just following the tutorial and trying to see if I have to do something manually with the help of the tutorial. Somehow the position for the rotor at t=0s is already set to 0 deg. And the instruction tells me to put the position to 7.5 deg even though the model is already set to 0deg. Is this a mistake inside the tutorial?
Here are some characteristics of the motor:
Motor ratings This motor with the following data:
Max bus voltage: 500 V
Peak torque: 400 Nm
Max speed: 6000 rpm
Peak power rating: 50 kW at 1200-1500 rpm
is designed for a hybrid electric vehicle.
Motor main
characteristics
Other characteristics of the studied motor are presented below:
48 stator slots
3 phase wye connected stator winding
4 pole pairs of the magnetic field
NdFeB magnets
Lamination type M270-35A
Outer diameter: 242 mm
Stack length: 75 mm
The tutorial is attached to this post.
