Altair RISE
Nominate Yourself Now!
PV Panel modulation
User: "Gonçalo Simão"
Altair Community Member
Updated by Gonçalo Simão
I would like to know if it's possible to configure a matrix of various strings of PV panels in parallel in Solar Module (Physical model)? If I multiply the parameters related to the current, will the program assume that the panels are in parallel?
Thank you.
Gonçalo Simão
1 - 1 of 11
    User: "NikosDimitrakopoulos"
    Accepted Answer
    Updated by NikosDimitrakopoulos
    Hello Nikos,
    I think it is not correct because the voltage calculated at MPPT continues to be higher for 500 W/m2 than for 1000 W/m2 as you can see below:
    For 500 W/m2:
    Vmax=39.97V
    For 1000 W/m2:
    Vmax=36.56V
    The IV and PV curves seems also sharper than the ones in the catalogue. What I sould obtain is something like the curves of the image below:
    I also don't undestand why I can't change all the values in solar panel utility since they are copied to the block of the PV Panel.
    Thank you very much.
    Best Regards,
    Gonçalo Simão
    Hi Gonçalo,
    You are right, the max voltage should increase with Light Intensity. Upon examining the datasheet once more I made the observation that this is either a 24V or 12V PV depending on how you connect the cells.
    The panel has 66 cells. I believe it has two 33s1p arrays. If you connect them in series (66s1p) you have a 24V panel. If you connect them in parallel (33s2p) you have a 12V that can provide double the current of the 24V case. So it's not a 11s6p connection as initially thought.
    The graphs of the datasheet should apply to the 24V case, so 66s1p connection:
    That being said, I tried to model this with the utility. Made some key changes:
    1.  I digitized the datasheet graphs and recalculated the correct dv/di to -0.276
    2. I changed the Ideality Factor A to 1.8 as this is a crystalline silicone panel. The PSIM manual suggest :" A good initial guess of the ideality factor A is around 2 for crystalline silicon, and is less than 2 for amorphous silicon. "
    These changes gave me some logical results across different levels of Lights Intensity. Please consider that 100% will not be achieved. As both the panel datasheet and the PSIM manual suggest, the given values and calculation techniques respectively are only trying to approximate the panel's behavior.
    That being said, you can use these values to approximate the behavior along a spectrum of different intensities. If accuracy to the datasheet graphs across all intensity is the main interest, I would create different models, each one parameterized for a specific intensity.
    BR,
    Nikos Dimitrakopoulos
