Does the XYZ coordinates change for 1D elements, What does this based on?
User: "Balasubramanian Dhandapani"
Altair Community Member
Updated by Balasubramanian Dhandapani
In my understanding, When modelling a 1D bar element, the XYZ coordinates are based on the System collectors.
As you can see the common XYZ axis in the bottom left and the XYZ axis on the 1D element.
Does this mean when I'm looking at results(for example shear force at each axis (X,Y&Z)) do I have to assume the Y result of 1D element means X is real-life conditions?
Just trying to understand this coordinate system relations, so whatever information I can get is much appreciated
Thank you.
1 - 1 of 11
