Can you please provide the required run options to run a job using GPU using a NVDIA Quadro P5000 card from the AcuSolve HyperWorks Solver Run pop-up window/gui. I tried the command below posted on a previous blog but does not work. Thanks.
It should simply be
-gpu
in that Additional arguments field.
Did it work.
