I am wanting to see the s parameters, magnitude and phase, through an arbitrary media. I am currently using multilayer green's function, with free space vacuum on either side and my media of interest as a layer in between. No ground planes. I have a plane wave source for excitation. The request is transmission/reflection. (Ideally I want s-parameters, but a port is required and the plane wave source does not register as a port to my knowledge.) If I view the reflection and transmission magnitudes over a large frequency band they match exactly to simulations in 2 other notable EM software programs. The S11 phase then matches for FEKO and the other two as well.
My issue is the transmission phase. How is this calculated? I get agreement for S21 phase for the other 2 softwares, but transmission phase in feko does not give correct results. If I change the distance that the plane wave travels through vacuum, the phase should change. However, in FEKO the transmission phase does not change. I tried changing the phase reference plane of the transmission/reflection request but again the transmission phase does not change whereas the reflection phase does.
Attached is a file for testing. Can run with the added free space layers once, then run again with the layers removed.
Please let me know how I can observe the transmission (ideally S21 or S12) phase change through the media. Perhaps a different request would be better?
Thanks for your help,
Lucas
