Hello all,
I'm experiencing issues with setting up an Hyperstudy optimization for a full vehicle manouvre built through Motionview.
The model itself is custom built, while the manouvre is a standard MotionView Event.
The manouvre is a normal constant radius turn, and runs perfectly if ran using MotionSolve:
However when the same model is plugged into Hyperstudy, it features the following error:
If I set up a full vehicle model only using the wizards belonging to the Vehicle Dynamics toolset within Motioview, Hyperstudy is able to read the .adf file an the optimization setup continues.
Has anyone experienced this before ? Does anyone have any ideas on how to fix this issue?
