Dear experts,
I want to mesh the geometry with AcuConsole according to the picture below (4 different layers):
The size in the x and y direction is several times larger than that in the z direction, lets say 1 m * 1 m * 0.003 m (x * y * z). I defined the absolute mesh size as 10 mm. Abviously, this leads to only one element per volume in z-direction.
Now to my questions: Which is the best setting to get at least 3 elements per height in z direction in the entire volume of one part (i.e. via different Volume Mesh Attributes for different volumes or by appliying a value for the Surface Mesh Proximity Level)?
Thanks in advance!
