Hi!
I am using the simcoder to generate code for my ti dsp. Usually, the controller process frequency needs to be higher than the switching frequency. However, Psim asks the pi controller in the z domain to have the same frequency as the PWM generator. Is there any way to raise the pi controller sampling frequency to the PWM generator frequency so I can generate a code that has a higher process frequency than the switching frequency?
Rick Li
