Dear Experts,
KIndly suggest excitation methods used in CMA other than ICE, CCE, probe fed mechanism to excite modes, Excitation based on symmetry. kindly help
In UWB case (3.1GHz -10.6GHz) for covering such a broad spectrum,
1. How many modes could be requested? ( if 3 modes are requested then what should be sorting frequency).
2. How many frequency samples can be requested for freq of 3Ghz and 10.6Ghz, such that there is no mode tracking error?
3. Finally, How to perform excitation with the knowledge three modes alone to cover the entire band with 7.5GHz?
Hi Sumithra, I would consider the following approach:
To answer some of your other questions:
All the best.
Hi Wilco Strydom,
Thank you so much for your valuable suggestions.
