Hello Team,
I intend to do Transient heat transfer analysis in SIMLAB by applying Constant Volumetric heat(Heat Source). I have applied dynamic loading for Convection. Apart from this, i have created Initial conditions (Ambient temp), thermal contacts, and defined proper load collectors, tstep appropriately.
Heat Source is constant in my scenario. I cannot define load by a table. Also, Volumetric heat is being used which takes Heat flux of the equation.
I would be glad if you could help me the methodology how to solve a transient heat transfer problem with constant Vol. heat loading.
I am attaching you the database file for your reference.
