I am running simulations for magnet models.
1. The strength of the magnet is sensed by an IC that remains at one position (PCB).
The sensor IC has a detection range (Min, Nom, Max) in mT in general.
I setup the strength of the magnet at a typical value, but this strenght has a minimum, typical and maximum value.
Since we are not modeling the Sensor in Altair, rather the Magnet, is there a way to enter both the min, nom and max value and then compute?
This would give me 3 detectable curves in one plot.
That means that looking from one angle (X-axis), I can see the Min, Nom and Max (on Y-axis).
Now I have one curve because I enter only the nominal (typical) strength value.
2. Since the magnet is sensitive to temperature and our product go in reflow process, is it possible to set the temperature to see how it affect the detection?
