Hello there,
I am trying to analyze a certain problem with regard to bearings. The situation is this. I have a transmission which is powered by an induction motor. The known values are the Power, RPM, gear specifications, and the specifications of bearings.
I wanted to get the reaction force of the bearings with the given inputs above. I tried so many times but the results of my analyses are far from what I expected. (Tried to manually compute it)
BTW here are some information about my set up
I have a total of 6 bodies involved in the analysis
2 gear shafts (driven and driver gears)
4bearings (2 bearings for each gear shaft)
Joints
All bearings are revolute to the ground body
Gear shafts are fixed to the gears
Motion
I input a motion to the driver gear base on the rpm of the motor
Forces
I applied rotational force to the driven gear as torque and made it negative (this acts as the force resisting the rotation of the driver gear) i used the toruqe equivalent to the power of the motor.
Contact
Applied Contact between gears
Ouput
Requested force output on the bodies (4 outputs for each bearing body)
I Hope you can help me with this. Thank you and God Bless
