i downloaded the student version of HyperWorks bundle 2022 and i activated the product. When i go to start a program other than than HyperWorks 2022 it shows me a license error.
Could you help me with this problem?
When did you activated the product? I think is a license error due to expiration of your current license. I 've been trying to find the solution to the same problem for the past couple of days.
I activated the license on March 7th.
All the troubleshooting steps necessary for student license issues are here - https://altairuniversity.com/altair-student-edition-licensing/
Can you once check whether the Ethernet ID of your machine matches the Ethernet ID in the license file? Or else can you run ipconfig/all in the command window and send the output here?
Also, refer to this article to identify the correct Ethernet ID of your machine - https://community.altair.com/community?sys_id=090bd87797031190e3b0361e6253aff0&view=sp&id=community_blog&table=sn_communities_blog
Watch this video on the process if needed - https://www.youtube.com/watch?v=Lp3zAFPRFlI
Hi, All the troubleshooting steps necessary for student license issues are here - https://altairuniversity.com/altair-student-edition-licensing/ Can you once check whether the Ethernet ID of your machine matches the Ethernet ID in the license file? Or else can you run ipconfig/all in the command window and send the output here? Also, refer to this article to identify the correct Ethernet ID of your machine - https://community.altair.com/community?sys_id=090bd87797031190e3b0361e6253aff0&view=sp&id=community_blog&table=sn_communities_blog Watch this video on the process if needed - https://www.youtube.com/watch?v=Lp3zAFPRFlI https://www.youtube.com/watch?v=Lp3zAFPRFlI
Thank you very much.
