As the title states , I cann't run it on simple mold ,and the prompt information is too simple ,and I can't obtain effectie information from it .Are there any special requirements for mold and work belt dimensions?
In the shared IEM file, the setup is incorrect. The flow volume is not properly organized.I used a shared CAD model and created an extrusion model with the correct organization.Please refer to the attached model.
Thanks
Hi, In the shared IEM file, the setup is incorrect. The flow volume is not properly organized.I used a shared CAD model and created an extrusion model with the correct organization.Please refer to the attached model. Thanks
Thanks,my email cannot receive the verification code. So I create a new account to thank you .I already know where my problem lies. I need to choose the correct starting surface of the work zone and set the length of the guide cavity.
Thank you again for your reply
