I'm trying to analyze a material which has different material properties in tension and compression. I tried different things but am not able to achieve the same.
As it's an orthotropic material I need to define these compression and tension data in all three directions. I read about MCIRON card image for concrete which pretty much does the same, but couldn't find it in the software.
Please suggest some steps that I can take here. Thank you in advance.
with regards,
Mithra Ramesh
