run matlab script from Hypermesh makro
User: "Torben0159"
Altair Community Member
Updated by Torben0159
is it possible to run a matlab script from a Hypermesh makro? What i want to do is
- setup modal analysis in Hypermesh
- run tcl makro, which executes the solver
- saving the pch file from the modal analysis
- run the matlab script (which imports the pch file and exports a txt file)
- import the txt file within the tcl script
- do some further actions....
Points 2-5 should all be done in the same makro. If it is not possible, how could you do that in another way (I dont know much about programming stuff yet)?
1 - 1 of 11
    User: "tinh"
    Accepted Answer
    Updated by tinh
    to run matlab script from hypermesh, you should write the script to a *.m file, and call matlab.exe with that *.m file
    set matlab "C:/path/to/matlab.exe"
    set matfile "C:/path/to/script.m"
    set matscript {
           ... do matlab calculations
    set fpt [open $matfile w]
    fconfigure $fpt -encoding utf-8
    puts $fpt $matscript
    close $fpt
    exec $matlab -r [string map {/ \\\\} $matScript]
