Hi everyone,
I am simulating a tensile test with Optistruct. The analysis is NLQS and the material is isotropic.
I set the analysis as proposed in the eBook 'Introduction of Non linear finite element analysis using Optistruct', section 3.1.5 Tutorial: Small-Strain and Large-Strain Plasticity in a Test Coupon.
I would like to understand how to set the CELAS1 element in order to use it for the building of the force-displacement output curve. I created the element, but the output curve results flat, so I think the problem is the Set.
Attached is the .fem file, is usefull.
Bests
Martina
