Analysis Result
Betül Özer
Betül Özer Altair Community Member
edited April 2021 in Community Q&A
Hello I have an important question. I got the topology optimization result in the hypermesh program and made a design according to the result in the cad program. For the linear analysis and modal analysis of my design, I included it in hypermesh again and defined what I needed to define in the same way. But as a result of the analysis, I cannot see my part. Why is my part not showing and analyzing results? As a result of the analysis, I see only the non-design area I have no design space. I couldn't understand why I couldn't get results. I have tried a lot to find the problem. For example, I changed the part name, increased the mesh size, rechecked the loading steps and others, but did not find the problem.
It gives an error as below. Can you help me?
  • Adriano Koga_20259
    Adriano Koga_20259 New Altair Community Member
    edited April 2021
    this is not an error. You are just trying to open the model, and it is asking if you want to discard the current model or not.
    As of your model part disappearing, it is probably due to your new part being disconnected to the rest of your model, thus the displacement is huge, and your part just "fly away".
    Try applying a 'deformed' scale factor  to decrease your displacement, and you will be able to see your part flying.
    Anyway, check your mesh connectivity or try building a freeze/tie contact between parts to ensure a proper connection.
