MacOSX link downloads an ".exe" instead of MacOS compatible application. Need alternative download link
HI , We have sent you an alternative link to download Inspire Studio for Mac OSX
we regret the inconvenience caused,
Hi Rahul,
I opened a case because I received an error during install on MacOSX(downloaded 2020 from the link you sent). Altair support suggested I install 2021.2 version of the program (2020 is an older version likely causing my error)
Can you resend a link with the latest version 2021.2
Thank you
We sent you the 2021.2 link as well just now, thanks
I'm having the same issue and was only sent an Inspire Studio link that is not compatible with Mac OSX. Additionally, there are no instructions that I can find regarding "setting an environment variable" for Mac OSX.
HI,
We sent you alternate links for the Inspire Studio supported in Mac OS X
Apple support may have instructions on setting environment variable in Mac OS X, however you may not need to set the variable since you can also just browse to the license file in the license set up window > and click activate.
