Hi, I need some help here....I want to mesh by cfd tetramesh but it show an error that the mesh is not enclosed. I already check for free edges but it do not found any free edge. How i want to fix this...?
Here i upload my file...hope you can help
i've tried here, both regular tetramesh and CFD tetramesh, in HM2021.1 and it worked just fine.
I've just selected the wall as BL, and inlet and outlet as 'w/o BL'.
What settings are you using? Are you picking all your elements/comps while meshing?
Tq. finally i can run the CFD tetramesh. may i ask how you view the inside of the component as per attached in the picture?
If you're using HW new interface, just turn on the section cut view
If using HM, I usually tke off the screen what i don't want, and use the 'mask not shown' to hide part of my model.
