i simulate a three-point-bending crash test of a FRP. Therfore i use 1 solid element over the thickness, a thick-shell property (22) and the material law 25. In the material law 25 i use the energy failure criteria with the element-deletion flag Ioff=2 and a specific Wpmax.
Unfortunately, when the energy failure criteria is reach, the element is not deleted but the stress is set to zero and hourglassing is beginning.
How do i let the elements be deleted if the failure criteria is reached?
Thank you very much!
Tim
