Non Linear Explicit
Zarana
Zarana Altair Community Member
edited October 2024 in Community Q&A
In Non linear Explicit - Optistruct Solver,
When we are using
TTERM=0.01
Load is applied as force in Z direction,
Is this mean, TTERM=0.01 means terminate the RUN at 0.01 time and Load is also applied as F*0.01 ,
Full load will get applied at Time =1.
  • Rajashri_Saha
    Rajashri_Saha
    edited October 2024
    Hi Zarana,
    In  NL explicit , TTERM=Termination time, nothing to do with load multiplication.
    Thanks
    Rajashri
  • Zarana
    edited October 2024
    Thank You for your reply.
    Please can you tell,
    what is the diffrenece between TTERM=1 and TTERM=0.01
    Because default termination time is 1.
    when I use 0.01 and 1, what is the difference it is gonna create in Analysis.
    One point I understood is with 1, computation time is higher.
    I want to understand, what is the difference it is going create on results.
    Thanks,
    zarana
  • Rajashri_Saha
    Rajashri_Saha
    edited October 2024
    Thanks,
    zarana
    If your model unit system is in Ton, mms, sec then the termination time unit is calculated in sec.
    Hence when you are running for 1sec, computation time will be higher compared to 0.01sec.
    Hope this clarifies your doubt.
    Thanks
    Rajashri
  • Zarana
    edited October 2024
    Thank you, got it
  • Rajashri_Saha
    Rajashri_Saha
    edited October 2024
    Zarana said:
    Thank you, got it
    You can mark the answer as correct so that the query will be in solved state. currently it shows unsolved.
