Hello, I've searched this forum and found quite a few similar experiences but no solution.
The problem occurs when I switch between linear static and non linear static analysis type.
The linear analysis works fine but when I try to run the non linear static analysis I get following error code:
License error:
Altair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorks, HWOptiStructFEA
Error Code: 9
Error Description:
Feature not found
Feature: OptiStructFEA
Error Code: 6
Error Description:
[LOCAL] C:\Users\****\Documents\Altair\altair_lic.dat - (Err: 9) Feature not found
[LOCAL] C:/Program Files/Altair/2020_1/security/altair_lic.dat - (Err: 6) Unable to read file
License Path: C:/Program Files/Altair/2020_1/hwdesktop\security\altair_lic.dat;C:\Users\****\Documents\Altair\altair_lic.dat;;C:/Program Files/Altair/2020_1/security/altair_lic.dat
License error:
Error Code: 9
Error Description:
Feature not found
Feature: OptiStruct
Error Code: 6
Error Description:
I've already tried all the suggested solutions, but nothing has worked so far.
Please help if you can. I'd be very thankful.
Edit: A friend with a full license just tried to run a non linear analysis on my model and it works. So the source of the problem must be in the student software version.
