Hello:
I have constructed a model by importing a geometry, creating a control volume around it and substracting (boolean) the geometry volume from the volume of control and using the result. It has properties of air, but now I would like to set punctual masses so that I can analyze gravity effects. May be it is incompatible with this form of modelling. How could I do it?
Thank you.
