i want to set the Unit of a Load in Hypermesh, but i cant find the UNIT Card for RADIOSS. Can sombody tell me, where i can find it or is it not supported in Hypermesh?
Tank you very much.
Best reggards
I know nothing about RADIOSS. But with almost FE software, there's no UNIT notion. The user should be warranty the consistency of unit for his input data.
Here's an example:
maybe you're talking about this:
It actually performs a kind of units convertion/scaling, between input model, and results output.
If you don't change anything here, the units used in your model will be the ones used.
Hi together,
first of all, thank you for your help. But i mean the Unit Card like in the figure down below. I cant find this one in Hypermesh. Does someone know this Card?
Best Reggards
