I am currently doing an Altair example from this PowerPoint, APPLICATION OF MAGNETIC FORCE EXPORT PER TOOTH:
VIBRATION ANALYSIS FOR ELECTRIC MOTORS AT MULTI-SPEED. The motor in the "Initial_files" from the zipped folder is not running. When opened in FluxMotor the error message would popped up. Is there a motor like this that would run in FluxMotor? I found another one, but it's only in Flux.
