Is it possible to initialize a transient simulation in Acusolve from CGNS file?
User: "Mahdi_22303"
Altair Community Member
Updated by Mahdi_22303
I would like to import mesh, and data from Fluent to Acusolve, and conitnue simulation inside Acusolve. I could not import a .cas file, but I could import the mesh file to Acusolve. Is it possible to import the data from Fluent and interpolate it on the imported mesh and continue a transient run in Acusolve?
Thank you,
Mahdi.
1 - 1 of 11
    User: "acupro"
    Accepted Answer
    Updated by acupro
    While I wouldn't necessarily recommend it - as a setup/mesh for Fluent isn't always a good setup/mesh for AcuSolve - you may be able to map as Initial Conditions in SimLab if you can get the mesh there also.  But it wouldn't handle CGNS.  It would need text files - x y z pressure, x y z temperature, x y z x-vel y-vel z-vel, etc.  Maybe you can export those from Fluent.
