I am working on a crash simulation between a pole and a beam in Radioss. However, when I am trying to set an initial velocity for one of the two parts in the Load Collectors section, INIVEL_Collector is not an option in the card images. The only 2 options are: SPH_INLET_OUTLET_Collector and ACTIV_Collector. Also, I tried using the search tool to find the INIVEL_Collector from there, but still when found, I can't set a velocity since the only card images are again SPH_INLET_OUTLET_Collector and ACTIV_Collector. Please note that I am using HyperWorks Desktop 2020.1 Student Edition and I've tried all the solutions that are suggested on this forum but nothing works. How can I use INIVEL_Collector and set my velocity?
Thank you.
