So If I keep the print size of 0.001 and solve for 15 sec, total number of processing step is 15000 so on and so forth. It takes a lot of time to render contour of the stress.
Is there some settings to increase the rendering speed?
If you are not interested to view all the 15000 frames, here are a few things you can do.
before hitting the Play icon in the animation toolbar, in the Animation controls panel,
1. You may increase the number of frames.
2. You may set a particular range Animate start and Animate end.
HyperView would then load only those many necessary frames.
regards
Praful
