I'm trying to use two AutoRider, one as a rider and other as a pillion. Is it possible to use this way ?
I'm getting error while solving this way.
Hello Aditya,
You can use AutoRider as a pillion. You need to add a Marker for reference and choose a body to which the pillion rider will be fixed.
Please note that as you add a rider to a two-wheeler, the mass distribution of the vehicle will change significantly. You might have to change the Driver controller gains to make the vehicle perform maneuvers as expected.
Regards
Raghavendra.
