I'm trying to simulate Fatigue Test Rig of the rear shock. Is there a way to know the bottom out condition ? How should I proceed ?
Hello Aditya
If you are building your two wheeler model using MotionView's built in two wheeler library, the fork system would have jounce and rebound bumper systems.
A non-zero force in the jounce bumper should indicate a bottom out condition.
Hope this helps.
regards
praful
Hello Aditya If you are building your two wheeler model using MotionView's built in two wheeler library, the fork system would have jounce and rebound bumper systems. A non-zero force in the jounce bumper should indicate a bottom out condition. Hope this helps. regards praful
Thanks Praful Sir. It was helpful.
