I created python script using SimLab before I use Hyperstudy.
And I played the script to check some errors, but It worked successfully.
However, whenever I use Hyperstudy, it doesen't work.
So I checked script log file, and I found that the CATIA model(.Part) didn't import.
But the model successfully imported when I played the script on SimLab.
How can I import model file on Hyperstudy? What was the problem?
