I want to import the stmod file. Whenever I imported it, I encountered the following error message. How can I import this file?
I can't still import the stmod file..
Thank you for confirming the Inspire installation path in "SimLabSetting.ini" file.
While importing the Inspire model, Parasolid file will be written in the model folder and it will be deleted after import.
Could you please check the write permission for the model folder?
Also, please put the Inspire model in the Desktop and import.
Kindly check this and let me know.
Thanks & Regards,
Santhoshkumar
Hello GyeongJun,
The information regarding the connection between SimLab and Inspire is stored in the “\.altair\SimLab_V2023.1\simlab\SimLabSetting.ini" file.
Kindly delete the .altair folder and reconfigure the Inspire 2023.1 version with SimLab 2023.1 and import the Inspire model.
If it still fails, kindly share the Inspire model. I will check and get back you.
Note: Before deleting the .altair folder for SimLab 2023.1 version, kindly take a back up.
Hello GyeongJun, The information regarding the connection between SimLab and Inspire is stored in the “\.altair\SimLab_V2023.1\simlab\SimLabSetting.ini" file. Kindly delete the .altair folder and reconfigure the Inspire 2023.1 version with SimLab 2023.1 and import the Inspire model. If it still fails, kindly share the Inspire model. I will check and get back you. Note: Before deleting the .altair folder for SimLab 2023.1 version, kindly take a back up. Thanks & Regards, Santhoshkumar
Hello. Thank you for your opinion.
'SimLabSetting.ini' doesn't exist in the location you gave me.
But, the file is stored in the "Altair\2023.1\Inspire2023.1\hwx\bin\win64\hw\hmbatch\hm\scripts\HyperMold\RTM\simlab_meshing" and "Altair\2022.3\hwdesktop\hm\scripts\HyperXtrude\simlab_meshing".
Which file should I delete?
Hello. Thank you for your opinion. 'SimLabSetting.ini' doesn't exist in the location you gave me. But, the file is stored in the "Altair\2023.1\Inspire2023.1\hwx\bin\win64\hw\hmbatch\hm\scripts\HyperMold\RTM\simlab_meshing" and "Altair\2022.3\hwdesktop\hm\scripts\HyperXtrude\simlab_meshing". Which file should I delete?
When you launch SimLab, it will create a folder in the .altair folder.
For example, if you open SimLab 2023.1 version, it will create "SimLab_V2023.1" folder as shown below. Kindly delete this folder.
Inside the "SimLab_V2023.1\simlab" folder, there is a file named "SimLabSetting.ini" file. Inside this file, the Inspire path will be written. Kindly check this file.
If you can delete the "SimLab_V2023.1" folder from .altair, then it will ask you to reconfigure the Inspire. Once you configure Inspire, we can import the Inspire model again and check.
Could you please share the model?
When you launch SimLab, it will create a folder in the .altair folder. For example, if you open SimLab 2023.1 version, it will create "SimLab_V2023.1" folder as shown below. Kindly delete this folder. Inside the "SimLab_V2023.1\simlab" folder, there is a file named "SimLabSetting.ini" file. Inside this file, the Inspire path will be written. Kindly check this file. If you can delete the "SimLab_V2023.1" folder from .altair, then it will ask you to reconfigure the Inspire. Once you configure Inspire, we can import the Inspire model again and check. Could you please share the model? Thanks & Regards, Santhoshkumar
I successfully delete the file, but I can't import stmod file. It isn't still working.
I select the Inspire installation location,
"C:\Program Files\Altair\2023.1\Inspire2023.1\hwx\bin\win64"
Is the location correct?
I referred this site. https://community.altair.com/community?id=community_question&sys_id=32b7a3091b723594507ca6442a4bcb06
I successfully delete the file, but I can't import stmod file. It isn't still working. I select the Inspire installation location, "C:\Program Files\Altair\2023.1\Inspire2023.1\hwx\bin\win64" Is the location correct? I referred this site. https://community.altair.com/community?id=community_question&sys_id=32b7a3091b723594507ca6442a4bcb06
Thank you for sharing the model.
I can import the Inspire model successfully in SimLab 2023.1 version. Please go through the attached video.
The Inspire installation location which you have specified is correct.
Could you please check the Inspire installation path is written in the "SimLabSetting.ini" file?
Thank you for sharing the model. I can import the Inspire model successfully in SimLab 2023.1 version. Please go through the attached video. The Inspire installation location which you have specified is correct. Could you please check the Inspire installation path is written in the "SimLabSetting.ini" file? Thanks & Regards, Santhoshkumar
Thank you for confirming the Inspire installation path in "SimLabSetting.ini" file. While importing the Inspire model, Parasolid file will be written in the model folder and it will be deleted after import. Could you please check the write permission for the model folder? Also, please put the Inspire model in the Desktop and import. Kindly check this and let me know. Thanks & Regards, Santhoshkumar
I apologize for the late response to your answer.
Thank you for your help.
SimLab successfully read the stmod file.
I think it is crucial to check write permission of "C:\Program Files\Altair\2023.1\Inspire2023.1\hwx\bin\win64".
Gyeongjun
