I have just set a non-linear quasi-static analysis with a contact suracface but I'm non sure if the results I obtained are corrected. In the loadcollector with card NLPARM I created, I filled the NINC field with the value 20, but I did it haphazard. Is there a value I have to set which is the best or does it depends on the load I have in the analysis? the forces I have is about 40000 N. Should I increase the value in NINC or should I decerease it?
Thank you
