Hi! I have a electric motor in my analasys that i would like to change wight on. How can i do that?
You can change the weight of a part by assigning a different material with appropriate density. You can do so from Assembly > Apply material.
SimSolid also allows you to add remote mass or distributed mass. Point masses can be added from connections > virtual connectors > remote mass.
Distributed mass can be added from the boundary conditions section within the respective analysis.
I hope this helps.
