Dear FEKO support team,
I have a wire antenna placed on an infinite ground plane modelled using CADFEKO and EditFEKO tools. The antenna geometry is identical in both the models, but I observe a shift in the impedance real and imaginary parts.
In the CADFEKO model each wire segment is defined as a copper medium.
and in the EDITFEKO model a SK card is added to define skin depth of the wire segment. The option "Exact expression for the skin effect" is used when modeling skin depth.
Can you please have a look at the attached models and let me know why there is a difference between the FEKO simulations?
