How can I retain my Assemblies from HyperMesh to HyperView?
Joseph Billman
Joseph Billman Altair Community Member
edited January 2024 in Community Q&A
When I create assemblies in the Parts Browser of HyperMesh, they does not come through in HyperView; instead Hyperview shows an Assembly Heirarchy, Components, and Models- but none of these entities include the assemblies I created. This means that in HyperView, I need to highlight parts in the graphics window, rather than just selecting my assemblies from the model tree (very time-consuming).
I am accustomed to using the Assemblies Browser in HyperMesh- which carries through to HyperView results, but I understand that the recommended workflow for HW2023 involves using the Parts Browser instead of the Assemblies Browser, so that's what I did.
The workaround I have found is to create SET_ELEM's in Hyperview - the downside to this is that the sets do not automatically update if I make any changes to the model (and of course this adds another step to the overall process).
Is there a better way to get HyperMesh Assemblies to carry through to HyperView?
Thanks.
  • Adriano_Koga
    Adriano_Koga
    edited January 2024
    with assemblies, I know that if you load your model (.fem) and results (.h3d), using 'math templat' as 'advanced', you would visualize model information as well. (material, properties, ...)
    With parts, honestly I haven't tested yet, but it should work.
  • Joseph Billman
    edited January 2024
    Thanks Adriano,
    When I do that I see Materials and Properties come in, but still no Assemblies.
    I should also add- when I open the results file in either the Advanced or Standard Math Template the Parts Entity includes some of the Part Assemblies, but not all, and they are not structured correctly.
  • Jason_Craanen
    Jason_Craanen
    edited January 2024
    Thanks Adriano,
    It should be available in the Parts Browser (Double click on Parts from home browser)
  • Joseph Billman
    edited January 2024
    Thanks Jason,
    This is the answer I was looking for, however I must add that assemblies which had their visibility set to hidden in the HyperMesh session did not make it into the results. When I displayed the assemblies in HyperMesh and re-ran it, the Part assembly hierarchy came through correctly. Export settings were set to the default "Custom", not to "Displayed", so I did not expect visibility settings to have this effect.
    Do I need to have all Part Assemblies displayed in HyperMesh in order for them to carry through to the results?
