I am writing to ask for information on how to properly set up a model for multiple subsequent
drop tests with stress and deformation recovery from the previous load case.
The final aim is to evaluate the ultimate damage and residual functionality (after 2+ drop tests) of the good being virtually tested.
To make myself clear: imagine having a toaster, which dropped from a certain height (hence the initial condition is v_0=sqrt(2*g*height)).
After the contact with the ground and the subsequent residual deformations in the structure, it is in my interest to understand if
there is any function already available in RADIOSS to map the deformations and stresses from this load case to the subsequent one, in which I am re-lifting the toaster, spatially rotating it and making it drop again.
I know that LS-Dyna has already received updates which implemented the mixed Eulerian-Lagrangian formulation + stress re-mapping, but I am wondering if the same could be done in RADIOSS too. And, if that's the case, is there any official guide publicly made available?
Thanks for any help or advince provied, it would be highly appreciated.
Kind regards,
Andrea Corazza
