I've built a 3 wheeler model on MotionView to analyze its handling during various standard tests. During Sinusoidal steering test, the Suspension travel was plotted against time and this plot shows a non-zero spring deflection at 0 seconds. Moreover, when the spring deflection is calculated manually using the spring stiffness and the tire load, the value does not match with the deflection value given in the plot. Kindly let me know why this is happening and how i could set the initial deflection at 0 seconds to 0mm.
Thank you
