How i can model a spring element with axial and radial stiffness in Optistruct?
Please Help?
As per my understanding PBUSH element have K4,K5&K6 for rotation stiffness not axial stiffness.
Please explain.
Thanks
Hemanshu
As per my understanding PBUSH element have K4,K5&K6 for rotation stiffness not radial stiffness.
Someone please reply asap.. Thanks
Yes K4,K5&K6 is for rotation stiffness.Please note, Rotational stiffness values are input based on rotations defined in Radians.
Thanks for the reply.
We want to model a composite (Rubber) hose as a spring (BUSH) element.
As, hoses are cylindrical (means they have axial and radial stiffness; Best to define in cylindrical co-ordinates) and curved (Not in single Plane). So, i have to model them with multiple bush elements (Each element in different Plane; best to define in cylindrical co-ordinates).
So, i want to know which bush element is most suitable for my application in cylindrical co-ordinates.
Please explain the procedure to define also.
I am attaching here file too showing one model as hose and one model as CBUSH (Just for explanation).
PFA old video of Bush element creation.
Thankyou rahul.
While defining CBUSH element in Cylindrical co-ordinates,
does
r refers to K1
z refers to K2
t refers to K3
or some different.
Otherwise can you reply me in my model by creating CBUSH elements with axial stiffness 19680 and radial stiffness 10?
Please revert.
Hello everybody,
@hemanshu
I need help regarding same. How u get stiffness value of composite rubber hose.
@Rahul
Is it possible to realize the crimp joint in better way.
any help
@Himanshu
@RAHUL
