tension only 1D element
Simon Križnik
Simon Križnik Altair Community Member
how to set up tension only (no compression, bending and torsion) 1D element in Radioss?
I have tried with truss and spring elements. However, truss elements have axial compression stiffness and there is discrepancy in the plots, possibly because of geometric non-linearity.
compression (truss in blue, spring in red color)
tension
Welcome!
  • Altair Forum User
    Altair Forum User
    edited June 2018
    hello!
    i haven't opened your model.
    at first, i don't now about altair, but it doesn't recomend to use no tension/no compression to beam/truss elements in abaqus.
    i'm looking for your model and will give some advice, but i'm just newbie in altair solvers.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    it's interesting, becouse i thought if i splite truss to 2 element i will have no compression force. i'm confuse, but it doesn't work in radioss...
  • Simon Križnik
    edited June 2018
    Hi Mrt,
    thanks for your input.
    My observation is if the force or displacement is applied coaxial to the truss/beam elements they will not buckle in compression, since FEA does not model material or geometry imperfections that would buckle the structure in reality.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    but spring works well, why don't u use it?
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Yeah, nonlinear springs. But, input is tricky,
  • Simon Križnik
    edited June 2018
    Thanks for suggestions,
    I will use one degree of freedom spring element (TYPE4) with nonlinearity defined through force-displacement curve.
Welcome!
Welcome!
