I am trying linear steady state heat transfer problem on a heat sink. I have given the temperature constraint to bottom of the heatsink, I have attached the hm file below. I am trying to select a node by id in constraints panel to give ambient temperature, but the node is not getting selected. Convection interface is all the faces except bottom face. I am trying to select a node in space not on the heatsink model. Please provide a solution on how to select a node in space for this problem statement or any other object? Mesh Quality Check is neglected.
