🎉Community Raffle - Win $25
Join and Win
PROGRAM STOPPED: ERRORS DURING ELEMENT QUALITY CHECK?
User: "Ajay_22186"
Altair Community Member
Updated by Ajay_22186
I am attaching the saved hm file of the model. The model is Heat Sink and we need to perform thermal stress analysis on it and the mesh is tetra elements.
The amount of memory allocated for the run is 800 MB.
This run will use in-core processing in the solver.
Element # 53622, element type TETRA.
*** PROGRAM STOPPED: ERRORS DURING ELEMENT QUALITY CHECK.
I am getting this error continuously even though quality is clean. Can anyone identify what's the mistake and provide a solution?
1 - 1 of 11
    User: "Adriano_Koga"
    Accepted Answer
    Updated by Adriano_Koga
    Your elements are not 'clean'.
    Just open the .out file and you will see some of the errors by the solver.
    You should review your elements, preferably.
    But, if you want to ignore some of the errors (by your own risk), you can use PARAM, CHECKEL, NO as mentioned also in the .out file. This will bypass the errors which are not critical.
    ITERATION   0
     Element # 53621, element type TETRA.
     WARNING - Outside of recommended range: Face Skew Angle =    84.301
               upper limit =    75.000
     ERROR - Acceptable range violation: Face Vertex Angle =    2.8567
             lower limit =    3.0000
     WARNING - Outside of recommended range: Edge Angle =    81.799
     WARNING - Outside of recommended range: Edge Angle =    82.430
     Element # 53623, element type TETRA.
     WARNING - Outside of recommended range: Face Skew Angle =    82.478
     WARNING - Outside of recommended range: Face Vertex Angle =    3.7718
               lower limit =    15.000
     WARNING - Outside of recommended range: Edge Angle =    84.496
     NOTE : other similar error/warning messages were suppressed,
            use PARAM,CHECKEL,FULL to obtain full report
     Element # 53625, element type TETRA.
     WARNING - Outside of recommended range: Face Vertex Angle =    3.0079
     Element # 53637, element type TETRA.
     WARNING - Outside of recommended range: Face Vertex Angle =    3.7731
     Element # 53673, element type TETRA.
     Element # 54918, element type TETRA.
     ERROR - Acceptable range violation: Edge Angle =    87.184
             upper limit =    87.000
     Element # 70314, element type TETRA.
     ERROR - Acceptable range violation: Edge Angle =    87.353
     Element # 101918, element type TETRA.
     ERROR - Acceptable range violation: Edge Angle =    87.182
     *** ERROR # 2203 ***
     Error(s) encountered during element check
    ***** Element Quality Check Failed - error limits violation *****
     NOTE : To bypass element quality checks (except essential validity checks)
     use PARAM,CHECKEL,NO. This may, however, cause very poor results.
     Element Quality Check Summary
