When I changed the generated rate(kg/s) of particles in factory, the error message would popup as figure. Can anyone explain this?
Hi Raheem,
Changing the units can trigger EDEM to think there was a change and ask you to save. It seems like the error is saying it can't overwrite the existing file. This could be file permissions related.
If instead of saving over the existing file can you save the simulation as a new file?
RegardsStephen
