I want to applied a certain pressure on the bulk consist of particleA through a geometry in z direction, however, the geometry was also constrained with particleB in x and y direction, if I want to control the pressure on the bulk like PID, I need to retrive the contact force between particleA and geometry in the code, I have looked through the IEDEMcoupling and cannot find which method is useful for this case. Or I need to include custom properties from else?
Reagrds!
Raheem
