I am working on thermal analysis.
There is a sliding contact between two different components. How do I ensure heat transfer between these two components?
Thank you.
Best Regards, Ovunc
Hi Ovunc,
Please take a look at the files attached. There is a model fully set up and a tutorial.
Use them as references and you will be able to set up your model properly.
If this answers your question, please consider marking it as a correct answer, because it will help others.
Thank you very much,
Does anyone have any information on the subject?
Best Regards,
Ovunc
