Altair RISE
Nominate Yourself Now!
SPH method - in-canal flow
User: "Ovunc"
Altair Community Member
Updated by Ovunc
I am trying to model the flow in the canal with the SPH method. The canal has the shape of a rectangular prism. I determined the surface where the flow will start by creating a csurf. SPH particles are produced in line with the normals of the elements on this surface. I aim for a continuous and dense flow of particles.
  1. I think that if I make the mesh on the yellow marked surface more fine, the particles will become denser. I also observed this. However, all particles were not formed at the same time. Why could this be?
  2. How can I make the particles in the x direction more dense? ( Is using finer mesh the only solution to this? )
  3. Particles are occurring far apart from each other in the y direction. The particles are forming as in Figure 1. So I don't observe continuous flow. How do I ensure continuous particle formation?
I would be glad if you help.
Thank you.
Best Regards,
Ovunc
                                        Figure 1
1 - 1 of 11
    User: "Ovunc"
    OP
    Updated by Ovunc
    Hello again,
    I wanted to explain the situation I mentioned on a simple model.
    As seen in Figure 2, as the mesh size of the inlet surface decreases, the particles  become more dense in the y direction. But the particle gap has increased in the x direction.
    • Why is this occurring? ( Do you think the particle distances should be the same in the x and y directions?)
    • You can also see in Figure 2 that although they have the same fluid properties, the fluid is in different positions at time t. How can the input surface mesh size be determined?
    Figure 1
    Figure 2
    Thank you.
    Best Regards,
    Ovunc
