Hello everyone,
I may be in need of a failure model in conjunction with either P3 or P18 beam elements and a LAW36 tabulated plastic material. The material is a plastic to the likes of polyamide, or something more ductile like a tough resin. The built-in failure method of LAW2 or LAW36 cannot be used as, according to the documentation, the total strain is not calculated in beam elements, which is necessary for the failure model. Can someone help figure out which failure model is appropriate for this kind of application? My knowledge about them is unfortunately very limited, and almost all failure models mention only solid and shell compatibility, with some stating nothing of the sort, which leaves the question of beam compatibility open. A very simple "element is deleted or disconnected above x strain or y stress" behaviour would be sufficient.
